My 3000th Post, AND A FEW PICS... - Page 7 - Cherokee SRT8 Forum
post #61 of 196 (permalink) Old 11-30-2012, 06:58 PM
LAFNGA5's Avatar
any chance you can get them extrude honed? ive got a set of stock manifolds i took a peek at and not too sure aside from gasket matching/animal weld removal if theres much more one can do
10's Best Be Coming
LAFNGA5 is offline
post #62 of 196 (permalink) Old 11-30-2012, 09:14 PM
Untouchable's Avatar
Nj.
8.90@157.59
Untouchable is offline
post #63 of 196 (permalink) Old 12-01-2012, 02:18 AM Thread Starter
Muellge's Avatar
Other than few specs of slag in primaries, I think it would be overkill. Just passing time and getting rid of the big stuff.
Five Door League...
Muellge is offline
post #64 of 196 (permalink) Old 12-02-2012, 08:55 AM
bushmaster3000's Avatar
Originally Posted by Muellge View Post
basket is mostly for cooling the pumps so they don't burn up, still draws from the tank.
I understand it is in the gas tank but still I'm thinking the draw out of it with this build may not give the bowl time to fully refill. But then again u haven't seen it in person. Looks like the return feeds back into it. Guess its a math game about two flows in one flow out.
~~~~~ Special Thanks to~~~~
Skip at Demon Performance
Bada$$ Tuner Johan!
bushmaster3000 is offline
post #65 of 196 (permalink) Old 12-02-2012, 09:03 AM Thread Starter
Muellge's Avatar
I should have typed, that it is pulling from the tank and not the basket. If it starts popping pumps I'll know its not cooling and not working. Going to have them set up so the other pumps only come on when the psi calls for it. Calvin and "Hobbs", style, lol....Will still probably have to keep a good 1/4 tank on it. As it is now, they bent the fuel level sender arm enough so that when I have a 1/4 tank left it reads as empty. Tricks the owner into making sure that I dont' run it on fumes.
I know you meant I haven't seen it in person meaning u , as the pics are on my desk!
Muellge is offline
post #66 of 196 (permalink) Old 12-02-2012, 09:05 AM
Those manifolds are tubular. You really don't want to make them any thinner, especially with a big inch high HP turbo motor that's going to get them really hot and crest alit of pressure in the manifolds. Just removing the weld slag will help flow and spool. How much....who knows but a 1/4 inch reduchtio in cross section is a huge impact on the total flow area.
J
JerseyBoy@Stage6 is offline
post #67 of 196 (permalink) Old 12-02-2012, 09:44 AM Thread Starter
Muellge's Avatar
I agree. not somethng like our intakes with plenty of material and a rough cast surface. These are already very smooth on the inside and not terribly thick. The goal was to get the crap out of the port area. I measured some of the spots, easy 1/8 inch on each side, some 3/16ths, do that on both sides and you've got a good 1/4 or more of opening. That should help the hotside do its thing.
Muellge is offline
post #68 of 196 (permalink) Old 12-02-2012, 10:22 AM
RIP Chuck G.
junior666's Avatar
I always go back to Peters setup.
Arrington iron 426
Stock intake untouched
85mm Arrington throttle body
Stock untouched manifolds
Made 1191 HP and over 1000 torque at 22 psi.
Power is not the issue cause he can't run at Max(comfortable) power anyway
due to other limitations.
That being said, I believe you will make considerably more power per pound
with the bigger cubes. Looking forward to seeing you use the box with the routed edges
for more than a bench
junior666 is offline
post #69 of 196 (permalink) Old 12-02-2012, 12:47 PM
Oooops lol yea I* not u lol. Ah I gotcha about where it pulls from, sounds solid. I think many stock vehicles use boost triggered pumps, sounds like a good way to go. You plan on running 2 constantly and one boost triggered? May not hurt to have two going all the time since fuel pumps are rated for some ungodly amount of run time.
post #70 of 196 (permalink) Old 12-02-2012, 01:10 PM Thread Starter
Muellge's Avatar
was thinking one and then a second for 1 psi through midrage boost and a third for more than 15 psi. two switches. No need to buzz the fuel too much under normal driving conditions.
Arrington iron 426
Yes those numbers are gawdy and are one of the reasons I went with your kit.
Chris what kind of heads on that motor?
The box is a great height for hand tooling on things.
Muellge is offline
Post up your snow pics! pjs1965 Off-Topic Discussion 40 02-12-2010 09:30 PM
3000th Post! I'm a PoHO! navyavi469 WK1 SRT8 General Discussion 17 02-20-2009 12:24 PM
Help! How do I post pics? Gravitas Off-Topic Discussion 8 10-29-2008 04:08 PM
Post Wax Pics TCZ WK1 SRT8 General Discussion 3 09-28-2008 07:35 AM
How To Post Pics uae455 WK1 SRT8 General Discussion 3 05-08-2007 11:50 PM
