What supercharger is good for daily drive - Page 3 - Cherokee SRT8 Forum
post #21 of 47 (permalink) Old 05-08-2012, 06:04 PM
Spinning aint winning!!
MEANSRT's Avatar
Originally Posted by Jack_Toepfer View Post
Air to water intercooling is significantly more efficient than air to air and you can ask anyone with a FAST car.
Air to air is more popular because of simplicity, appearance and cost. Yes, you can make a lot of power on air but how many people with over 2000whp are running air to air intercoolers? I'd venture to say not many.
All of the manifold type chargers available are air to water and they do ok. The Vortech is air to water. The Procharger is air to air. Realistically with our Jeeps at our power levels it is personal preference. As long as the pipes and couplers stay intact and you don't hit anything the air to air is incredibly reliable. If you're worried about pumps failing or plumbing leaking, air to water is probably not the best approach for you. If your pump fails your intercooler is essentially useless.
Another very good way of cooling your intake charge would be with meth injection or nitrous. I'll probably do meth with my install. Liquid intercooler FTW. hehe.
Exactly my thoughts I dont understand why people think air to air is more effecient. I watch my IAT's constantly with the trinity and my jeep is usually only like 10 degrees over ambient with the blower. And then when im in the boost it with heat up more and very quickly drop right back down to 10 degrees over ambient.
I know maximillion can agree with me on this. And it should be noted it gets hot as hell out here in the high desert. The pump doesnt worry me from if i just turn the key to acc. you can here it come on before start up and with the trintiy you would know for sure if your pump was not working.
BTW the Bugatti Veyron has air to water intercoolers and I think they probably know a little bit about effeciency. LOL
2007 Jeep SRT8, Steel blue, Vortech V3 boosted, 30 tooth Pulley, Magnaflow mids, Borla S, Custom blower cam, Paramount trans, Wavetrac LSD, Johan tuned (Sold)
(And now bought back)
2008 Jeep SRT8, Brilliant black, R1 concepts rotors, Stoptech pads, Bwoody springs, Bwoody endlinks, Stage 6 shocks, Vortech V2 Ti HD boosted, 30 tooth pulley, Magnaflow mids, Borla S, Johan tuned (Sold)
MEANSRT is offline
post #22 of 47 (permalink) Old 05-08-2012, 06:37 PM
Knuckles's Avatar
I think Air to water intercooling is better up to 10 psi.. Once you go past 10 psi an air to air intercooler will be more efficent..
Knuckles
Knuckles is offline
SRT-MANA (05-09-2012)
post #23 of 47 (permalink) Old 05-08-2012, 08:28 PM
That is completely system dependent. A stock Maggie intercooler and pump may not be very effiicient above 10psi. A larger pump, tank and intercooler would solve that up to the cooling capacity of the heat exchanger on the blower. Once that is out of its efficiency range, you're making more power than I would recommend out of that 2300.
In contrast, Procharger claims that they are using their 1000hp intercooler with their P1 kit. So you could essentially run out of motor before you run out of blower and intercooler.
My cobra ran the stock heat exchanger from the terminator motor with a 76mm turbo. The benefits were 2 fold. Not only is the turbo more efficient to begin with it was paired with an air to water cooler, I could hot lap the crap out of that car and never worry about water temps.
Ice, which is just about free can be used with the air to water kits for near unlimited cooling capacity. The only thing that comes close would be meth or N2O because they are always going to actively cool the charge temps and don't require air to flow over the intercooler.
Jack_Toepfer is offline
post #24 of 47 (permalink) Old 05-08-2012, 09:26 PM
JohnsonSRT8's Avatar
Any of you know if you can run meth with the magnacharger? I know you can with the Vortech, Procharger, I ran it on my vortech on my 07. But not sure of you can run it through the magnacharger or is there a inlet after the lobes?
Now the owner of a 2010 Black GCSRT8 as of Dec 19 2011
(Gone)2007 Black GCSRT8 went from new all stock to--->Modded to $hit, BLOWN by Vortech running 11's to--->BONE stock
JohnsonSRT8 is offline
post #25 of 47 (permalink) Old 05-08-2012, 09:47 PM
Magnacharger may not warranty it if you do, but if nobody on here has done it in sure people on the ls forums are.
post #26 of 47 (permalink) Old 05-09-2012, 01:09 AM
MEANSRT's Avatar
I know on other roots style blowers meth has be known to eat up the teflon coatings on the rotors when injected pre supercharger I had problems with this on my 01 lightning I used to have.
MEANSRT is offline
post #27 of 47 (permalink) Old 05-09-2012, 04:12 AM
SRT-MANA's Avatar
Send a message via AIM to SRT-MANA
I agree....I would think exspecialy in slow stop & go traffic a air to air cooler won't help much,because your not moving fast enough to make use of the cooler vs vortech power cooler pumping cool water thru the power cooler.I drive thru a bunch of stop & go traffic daily & when I get home & pop my hood to touch the power cooler, it's very cool to the touch.so I know its doing its job.it feels great knowing the power cooler is ready with cool air at any giving moment,just incase I have to lay it down at a light with someone.
SRT-MANA is online now
post #28 of 47 (permalink) Old 05-09-2012, 06:31 AM
Knuckles's Avatar
Will see what IAT temps are when I install this Procharger....
Knuckles is offline
post #29 of 47 (permalink) Old 05-09-2012, 09:13 AM
stanfna's Avatar
I am definitely interested in this. i plan on supercharging my rig in August. since mine is a DD and i will rarely track it (more stop & go than high speeds), it sounds like i should go with a good air to water system. my biggest question is roots vs. centrifugal. how much more will a roots system cost, which is more reliable and what are the performance differences.
from what i am reading, it sounds like the pro charger air to water may be the best bang for my buck considering my needs?
thanks in advance for all the great feedback guys!
2010 fully loaded
Performance: ProCharger D-1SC, DMH cutouts, BT Catch Can, 180 tstat
Other: Toyo Proxes STII 315/275, slotted/dimpled R1 Rotors & Stoptech pads, Full interior LEDs, HID reverse lights, rear fog light harness, CHR550 w/ front facing camera, liquidomes, 5% tint, Shorty antenna, debadged, SRT8 badge on 1/4 panels, SRT in the lower grill, tinted tails
stanfna is offline
post #30 of 47 (permalink) Old 05-09-2012, 09:25 AM
DemonPerformance's Avatar
The ProCharger system that's made for these rigs does not have an air to water option, the only way to go about doing that would be going the custom route. Which will take a good bit of playing around and probably more coin than you want to spend, unless you find an old GSM Paxton Novi kit and swap the head to a ProCharger head. Or piece everything together, like a hybrid ProCharger/Vortech kit. It can be done.
You guys have to understand that both air to water and air to air have their ups and downs, both are great concepts and have been proven to be reliable. I personally would go air to water in anything that would be a big hp drag car with a centri blower/big turbo setup, reason being I can freeze the "water box" down after every pass and be ready for the next. On a go fast street car I would go air to air all day long however.
Skip » Demon Performance
1-888-312-3666
DemonPerformance is offline
good daily driver tires crazyman301 WK1 Wheels & Tires Discussion 18 12-21-2010 01:19 PM
Which Brake Pads Ebc Red Stuff Or Hawk Hps For Daily Use And Spirited Drive waldramos WK1 Brake Discussion 2 06-24-2009 04:25 PM
Need a good tune for Vortec supercharger setup Heiss M3 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 0 03-07-2009 12:28 AM
Supercharger or other mods - Daily driving??? adhesive WK1 Engine Performance/Superchargers/Turbos/Nitrous 21 09-20-2007 07:35 PM
