What supercharger is good for daily drive - Page 2 - Cherokee SRT8 Forum
post #11 of 47 (permalink) Old 05-08-2012, 02:53 AM
Spinning aint winning!!
MEANSRT's Avatar
Originally Posted by sankaku.garami View Post
I know Vortech is the old dog now, with procharger coming out, and twin screw blowers getting more common, but really nothing has the track record for reliability and longevity like Vortech since it has been around the longest for our jeeps. Mine is driven pretty regularly, and has been for 15k boosted... no problems.
Vortech, Maggy, Procharger, etc will be far more than your "little more power", you'll love any of them.
Could'nt have said it better myself.
2007 Jeep SRT8, Steel blue, Vortech V3 boosted, 30 tooth Pulley, Magnaflow mids, Borla S, Custom blower cam, Paramount trans, Wavetrac LSD, Johan tuned (Sold)
(And now bought back)
2008 Jeep SRT8, Brilliant black, R1 concepts rotors, Stoptech pads, Bwoody springs, Bwoody endlinks, Stage 6 shocks, Vortech V2 Ti HD boosted, 30 tooth pulley, Magnaflow mids, Borla S, Johan tuned (Sold)
MEANSRT is offline
post #12 of 47 (permalink) Old 05-08-2012, 05:48 AM
bcm0018's Avatar
For 6 k I think you could get a stroker shortblock and cam and be running just as well as a SC jeep. I like being N/A cause you cant tell its stroked by looking all you can hear is the cam.
09 SRT8GC HHP built stroker 604/555 - 10.753 PB
bcm0018 is offline
The Following User Says Thank You to bcm0018 For This Useful Post:
Blkoutsrt8 (05-08-2012)
post #13 of 47 (permalink) Old 05-08-2012, 06:24 AM
mcopare's Avatar
But what about install costs?
His - 2015 Jeep SRT (Brilliant Black)
Hers - 2014 Dodge Durango R/T (Brilliant Black)
mcopare is offline
post #14 of 47 (permalink) Old 05-08-2012, 07:41 AM
bcm0018's Avatar
I havent looked to recently at short blocks but I'm thinking 3500-4k, cam 475, springs/retainers ~250 and just keep the heads, manifold and intake (upgrade later) and I think its cheaper than a SC so in the end after install I imagine cost would be about the same. Not sure on the install I'm a DIY kind of person.
bcm0018 is offline
post #15 of 47 (permalink) Old 05-08-2012, 07:55 AM
mcopare's Avatar
I will be installing blower myself...no way I would do a short block though.
mcopare is offline
post #16 of 47 (permalink) Old 05-08-2012, 08:15 AM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
To get into the engine, you're talking $10K easy....trust me, I just went through this before the Procharger.
Sure a shortblock is $3500-$4500, then add core charge, ported heads w/core charge, ported intake manifold w/core charge, 90mm throttle body, camshaft, push rods, lifters, timing assembly, gaskets, ballancer, cam bolt, oil, coolant, injectors, flex plate, tq converter, tranny fluid, tuning, etc......then add labor. Shortblock will actually take more labor, because the the heads and cam have to be installed, and piston to valve clearance has to be checked. Longblock is usually cheaper on labor.
SC is the cheaper route, without a doubt. You may be able to throw together an engine on a low budget, but you need lots of supporting mods to make good power and run strong at the track with a stroker.
StangSlayerMA is offline
post #17 of 47 (permalink) Old 05-08-2012, 09:14 AM
bcm0018's Avatar
I agree on the 10K for everything but he doesnt have to do ported heads, core charges are refundable so I neglected them, and the intake and TB can also be done later. I will agree the SC is probably cheaper and easier to install but I think in his price range he could do the bare minimum on a stroker and then upgrade the rest as he saves more money. Just wanted him to think about it. Depends on his final goals for his jeep and how he wants to get there.
Kind of getting off topic so sorry OP.
bcm0018 is offline
post #18 of 47 (permalink) Old 05-08-2012, 09:59 AM
Marylandm3's Avatar
Superchargers seem to be personal preference...Procharger seems to be pulling away from the pack though..
Jason
2009 Silver Jeep Srt-8
DTP Racing
RIP RoKDoG
Marylandm3 is offline
post #19 of 47 (permalink) Old 05-08-2012, 10:24 AM
You gotta count core charges, you don't get that money back untill all is said and done, especially if you don't live near an authorized installer.
I just think its a total waste of money to tear apart the whole engine and not do ported heads, ported intake manifold, headers, forged push rods, valve springs, retainers, and a 90mm TB.....especially if you are doing a stroker. Those parts are pretty important to the final hp #. Its tough to break the 500 hp mark without them. You end up spending a large amount of cash, for moderate performance. Then dissapointment sets in when you realize you have to spend over $3K to go back and do heads.
It's best to tear the engine apart as few times as possible. Its hard to justify replacing the shortblock, paying to reinstall stock heads......and then pulling it apart later only to have to pay all that labor again. The labor will add up to be more than what heads would have cost the first time around. Thats called penny wise, and dollar foolish.
The Following User Says Thank You to StangSlayerMA For This Useful Post:
mcopare (05-08-2012)
post #20 of 47 (permalink) Old 05-08-2012, 04:47 PM
Air to water intercooling is significantly more efficient than air to air and you can ask anyone with a FAST car.
Air to air is more popular because of simplicity, appearance and cost. Yes, you can make a lot of power on air but how many people with over 2000whp are running air to air intercoolers? I'd venture to say not many.
All of the manifold type chargers available are air to water and they do ok. The Vortech is air to water. The Procharger is air to air. Realistically with our Jeeps at our power levels it is personal preference. As long as the pipes and couplers stay intact and you don't hit anything the air to air is incredibly reliable. If you're worried about pumps failing or plumbing leaking, air to water is probably not the best approach for you. If your pump fails your intercooler is essentially useless.
Another very good way of cooling your intake charge would be with meth injection or nitrous. I'll probably do meth with my install. Liquid intercooler FTW. hehe.
Jack_Toepfer is offline
MEANSRT (05-08-2012)
good daily driver tires crazyman301 WK1 Wheels & Tires Discussion 18 12-21-2010 12:19 PM
Which Brake Pads Ebc Red Stuff Or Hawk Hps For Daily Use And Spirited Drive waldramos WK1 Brake Discussion 2 06-24-2009 03:25 PM
Need a good tune for Vortec supercharger setup Heiss M3 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 0 03-06-2009 11:28 PM
Supercharger or other mods - Daily driving??? adhesive WK1 Engine Performance/Superchargers/Turbos/Nitrous 21 09-20-2007 06:35 PM
