Procharger install complete! - Page 10 - Cherokee SRT8 Forum
post #91 of 135 (permalink) Old 04-07-2012, 06:11 AM
DemonPerformance's Avatar
Jeff has the complete Ho kit, it comes with their BAP setup and the wiring harness for it(FlowCharger)
Skip
Skip Demon Performance
1-888-312-3666
DemonPerformance is offline
post #92 of 135 (permalink) Old 04-19-2012, 10:15 PM Thread Starter
jeffstar's Avatar
SO I finally, finally, finally got my gauges from Aeroforce ....
Boost is only at 5lbs max, I've checked the belt it is not slipping, I've bypassed the surgevalve and capped it off for just a test run and had the exact same results, 5lbs max. I've got PLENTY of fuel....I've checked all the pipes and I can't find any leaks/loose connections.
Any suggestions? Procharger says Dyno the truck and if there are no leaks they'll send me a smaller pulley if I want or I am disappointed with the dyno power level.
JeffSTAR
1987 Buick T-Type
2008 Grand Cherokee SRT8
jeffstar is offline
post #93 of 135 (permalink) Old 04-19-2012, 10:36 PM
Did you install the boost/vacuum sensor with the gauges? Just wondering if you need it...Can the gauge read boost from the OBD port?
How do you like the gauges?
First Jeep is offline
post #94 of 135 (permalink) Old 04-19-2012, 11:04 PM Thread Starter
jeffstar's Avatar
Yes it takes the data straight off the computer, which gets it from the SRT4 MAP.....
KPA that the gauge displays is also equiv to 5lbs of boost
It's not the gauge
jeffstar is offline
post #95 of 135 (permalink) Old 04-20-2012, 07:37 AM
jmkiesz's Avatar
Johan should be able to see the boost in your logs. Jose can figure it out I have not got to that level of reading logs yet. It sounded easy but I have not got around to it. Its funny mine was to high and yours is to low. I switched pulleys and now I am happy with 7-8 Psi. It was only $89 for a new pulley not bad at all.
07 BLK GCSRT on 22" FR with Nitto 420's
76 mm single Turbo
SHR Trans
Snow Performance Stage 3 Meth Injection,
3" Cutout w/MagnaFlow Cat-Back
jmkiesz is offline
The Following User Says Thank You to jmkiesz For This Useful Post:
jeffstar (04-20-2012)
post #96 of 135 (permalink) Old 04-20-2012, 07:47 AM
Spinning aint winning!!
MEANSRT's Avatar
Subtract 14.7 from your map psi and there's your boost.
2007 Jeep SRT8, Steel blue, Vortech V3 boosted, 30 tooth Pulley, Magnaflow mids, Borla S, Custom blower cam, Paramount trans, Wavetrac LSD, Johan tuned (Sold)
(And now bought back)
2008 Jeep SRT8, Brilliant black, R1 concepts rotors, Stoptech pads, Bwoody springs, Bwoody endlinks, Stage 6 shocks, Vortech V2 Ti HD boosted, 30 tooth pulley, Magnaflow mids, Borla S, Johan tuned (Sold)
MEANSRT is offline
post #97 of 135 (permalink) Old 04-20-2012, 07:54 AM
Knuckles's Avatar
Not sure if it makes. Difference, but I think he is running the P1SC head versus other guys who are running a D1SC Jeff..... Interesting to see if this is where the difference would be because like you said I saw 8.77 psi kn one of your logs.....
Knuckles
Knuckles is offline
post #98 of 135 (permalink) Old 04-20-2012, 08:05 AM Thread Starter
jeffstar's Avatar
I'll make a few logs on the way to work, WOT hasn't been tuned by Johan yet so keep in mind it runs pig rich with very little timing.
jeffstar is offline
post #99 of 135 (permalink) Old 04-20-2012, 08:16 AM
Hmmmm 5psi huh? I'm assuming your AFR is in the low 10's right now Jeff?
post #100 of 135 (permalink) Old 04-20-2012, 08:18 AM
Knuckles's Avatar
Ok got ya..... So which head do you have on your jeep Jeff?
Knuckles is offline
Procharger Install has begun jmkiesz WK1 Engine Performance/Superchargers/Turbos/Nitrous 70 04-07-2012 10:39 PM
Complete AEM A/F Guage install how to w/pics CentralTexHemi WK1 Tuning/CMR/Dyno/DataLogging/Gauges 49 03-23-2012 08:46 AM
Procharger HO Install Special jeff@hhp High Horse Performance 0 01-18-2012 03:01 PM
HOW TO: Complete AEM A/F Guage install how to w/pics CentralTexHemi Tech Tips - DIY - How-To 6 09-25-2009 04:27 AM
My Sub install is finally complete stevesvt WK1 Audio/Video/Nav/UConnect/Electronics 10 09-13-2007 01:05 AM
