Meth install pics - Cherokee SRT8 Forum
 48Likes
post #1 of 60 (permalink) Old 02-13-2017, 10:37 AM Thread Starter
bxcharger's Avatar
Meth install pics
Anyone have some pics of their meth install where they are tapping the washer fluid tank? Need to install min and am looking for some ideas.
Procharger D1, 17% OD pulley, Thitek 6.1 ported heads, Kooks Headers, Fore Fuel Rails, Custom BOV pipe w/Big Red, Corsa Exhaust, Ported intake manifold, 87MM TB, 180T-Stat, Lowered on Eibachs, Bwoody sway links and Panhard bar, Aadcco front and rear sway bars, JBA upper control arms, QA1 shocks, Full Infinity Kappa perfect set up with Kenwood, Carbon fiber Stryker hood, Carbon Fiber rear Spoiler, Carbon Fiber interior, 11" headrest monitors, 22" Chrome wrapped in 275/315 Vreds
bxcharger is offline
post #2 of 60 (permalink) Old 02-13-2017, 11:09 AM
Thread Derailer
Passmg2's Avatar
Hey Mick, mine is in the back just cause on the wk2 there is more room to run the 2.5 gallon tank. Some others must have used their windshield washer tank...that would have been stealthier fo sho!
bxcharger likes this.
10.998 @ 126.80
Passmg2 is offline
post #3 of 60 (permalink) Old 02-13-2017, 12:26 PM
Mohpar's Avatar
You running meth now?
Sent from my SM-N910W8 using Tapatalk
Passmg2 likes this.
2014 SRT - Forged Internals, Supercharged,Headers, 22" Rims, Borla S exhaust.
Mohpar is online now
post #4 of 60 (permalink) Old 02-13-2017, 12:39 PM Thread Starter
bxcharger's Avatar
Yeah I read some have, so I want to go that route. Hopefully some chime in with pics.
post #5 of 60 (permalink) Old 02-13-2017, 12:53 PM
Boosted Turd
JeepFreak12's Avatar
Hope this picture helps. I located my nozzle maybe 8" before the IAT sensor
5000XD, bxcharger, Jfra and 1 others like this.
2010 Brilliant Black SRT8: All Black D1 Procharger, Paramount Conqueror Trans, ProTorque 3200 stall, Demon/Fore Fuel System, and some fancy crap.. 11.27 @120
JeepFreak12 is offline
post #6 of 60 (permalink) Old 02-13-2017, 12:54 PM
Boosted Turd
As for the bottle. Just tap into the bottom of the washer fluid tank. Super easy
post #7 of 60 (permalink) Old 02-13-2017, 01:24 PM
The ModMan
5000XD's Avatar
Dumb question. So you just spray wiper fluid??????
Nice engine bay by the way!
Passmg2 likes this.
5000XD is offline
post #8 of 60 (permalink) Old 02-13-2017, 01:28 PM
Boosted Turd
No. Drain out your washer fluid and refill with the meth of your choice. Washer fluid contains some methanol in it (I believe 5% on most off the shelf stuff). But you can use the meth/water mixture (usually 50% meth) as windshield solvent.
5000XD and Jfra like this.
The Following User Says Thank You to JeepFreak12 For This Useful Post:
5000XD (02-13-2017)
post #9 of 60 (permalink) Old 02-13-2017, 01:39 PM
The ModMan
5000XD's Avatar
Aha!! Good 1.
5000XD is offline
post #10 of 60 (permalink) Old 02-13-2017, 01:42 PM
Thread Derailer
Passmg2's Avatar
Actually windshield washer fluid (the blue stuff) is a perfect mix to use. It's about 35% methanol and 65% water if I'm quoting my guru sources correctly and if I'm not they will chime in and tune me up. Boost Juice is pink and 51% water and 49% methanol I think. You can buy straight, clear methanol and mix your own with distilled water. The water is as important as the meth. Straight meth is too dangerous and adds no additional value. Again, if I remember correctly, water has a greater affect lowering exhaust gas temps and the meth does a better job lowering air intake temps so using the two together is perfect and you can experiment with the mix. And water will never detonate. Some guys use straight water. Yeah, windshield washer fluid works perfectly fine and is easy to get.
5000XD, Jack_Toepfer, Jfra and 1 others like this.
Passmg2 is offline
Stage 2 snow meth kit install help Vinnysrt8 WK1 General Performance Discussion 8 10-22-2012 05:37 PM
Pics of my N02 install!!! Grip Grip WK1 General Performance Discussion 16 04-08-2009 11:11 PM
Zex Install W/Pics billyboys WK1 General Performance Discussion 8 03-22-2008 09:53 PM
V1 Hardwire Install w/Pics Jeep Trick WK1 SRT8 General Discussion 12 10-30-2007 03:49 AM
H/C Install pics bevsjeepsrt8 Pics & Video Showoff Section 12 01-30-2007 05:47 PM
